Specifies the default VLAN ID on the port for MSRP data stream. The sr-pvid serves as a recommendation to connected AVB devices; AVB devices may still use other VLAN IDs if they are configured to do so.
| msrp | Multiple Stream Registration Protocol |
| port_list | List of ports in the switch. |
| all | All the ports in the switch. |
| sr-pvid | Default VLAN Identifier for stream-related traffic. |
| vlan_tag | VLAN ID ranging from 1 to 4094 (default is 2). |
2.
Use this command to specify the default VLAN ID on the port for MSRP data streams. The sr-pvid serves as a recommendation to connected AVB devices; AVB devices may still use other VLAN IDs if they are configured to do so.
# configure msrp ports 1,2,3 sr-pvid 2
This command was first available in ExtremeXOS 15.3.
This command is available on platforms that support the AVB feature pack license and have it installed. For complete information about software licensing, including how to obtain and upgrade your license, and which platforms support the AVB feature, see the Switch Engine v33.1.1 Licensing Guide document.
